Changing object properties
After you’ve created an object, you can change its properties. There are several ways to do this, including using the property bar, color palette, and dialog boxes. For more information about changing the default properties for new objects, see Setting the default property values.
In addition, you can copy object properties such as outline, fill, and text properties from one object to another. For more information, see Copying object properties, transformations, and effects.
