• | To quickly change the color of a text object |
• | To change the color of a text selection |
• | To add a background color to text |
Left to right: Background color is applied to artistic text, paragraph text, and selected characters
1 . | Using the Pick tool , click a text object to select it. |
2 . | Perform a task from the following table. |
Right-click any color swatch on the default color palette or drag a color swatch to the edge of a character in the text object.
1 . | Using the Text tool , select a character or a block of text. |
If the Property manager docker is not open, click Window Property manager. |
2 . | In the Property manager docker, click the Character button to display the character-related options. |
3 . | In the Character area of the Property manager docker, perform one or more tasks from the following table. |
In the text color area, choose a fill type from the Fill type list box, open the Fill picker, and then click a color or a fill.
In the text color area, click the Fill settings button , and modify the settings in the dialog box.
In the text background color area, choose a fill type from the Background fill type list box, open the Fill picker, and then click a color or a fill.
In the text background color area, click the Fill settings button, and modify the settings in the dialog box.
In the text outline color area, click the Outline width button, and choose an option from the list.
In the text outline color area, click the Outline color picker, and click a color.
In the text outline color area, click the Outline settings button , and modify the settings in the Outline pen dialog box.
Using the Pick tool , select the text. Open the Background color picker on the property bar, and pick a color.
Using the Text tool , select the characters. Open the Character background color picker on the property bar, and pick a color.
You can also add a background color to text by using the Background color controls in the Character area of the Property manager docker. To access the Property manager docker, click Window Property manager.
