• | To choose color-conversion settings |
When you choose color profiles, colors are matched between devices as closely as possible by the color management module (CMM) of the Microsoft Image Color Management (ICM), which is the default CMM. Color management modules are also known as "color engines."
You can also use the Adobe CMM if it is installed on your computer.
Handling pure black and grayscale colors
1 . | Click Tools ![]() ![]() |
2 . | In the Color conversion settings area, choose a color engine from the Color engine list box. |
Enable the Preserve pure black check box.
Enable the Map gray to CMYK black check box.
