When you convert a vector graphic to a bitmap, you can apply special effects that are unavailable for vector graphics or objects. The process of converting a vector graphic to a bitmap is also known as "rasterizing."
When you convert the vector graphic, you can select the color mode of the bitmap. A color mode determines the number and kind of colors that make up the bitmap, so the file size is also affected. For more information about color modes, see Changing the color mode of bitmaps.
You can also specify settings for such controls as dithering, anti-aliasing, overprinting black, and background transparency.
When you export a file to a bitmap file format, such as TIFF, JPEG, CPT, or PSD, the same bitmap conversion options are available. For more information about exporting, see Exporting files.
2 . |
Click Bitmaps Convert to bitmap. |
Dithered — simulates a greater number of colors than those available. This option is available for images that use 256 or fewer colors. |
Always overprint black — overprints black when black is the top color. Enabling this option prevents gaps from appearing between black objects and underlying objects when you print bitmaps. |
You can change the black threshold for the Always overprint black option. For information about setting the black threshold, see To set the overprint black threshold.
If you export a vector file to a bitmap format, such as GIF, you are prompted to set the bitmap conversion options described in the procedure above before you export the file.
Making the background of a bitmap transparent lets you see images or a background otherwise obscured by the bitmap background.
3 . |
Choose a bitmap file format from the Save as type list box, and type a filename in the File name list box. |
5 . |
In the Convert to bitmap dialog box, type values in one of the following pairs of boxes: |
Width and Height — let you specify the image dimensions |
Width % and Height % — let you resize the image to a percentage of its original size |
Always overprint black — overprints black when black is the top color. Enabling this option when you print bitmaps prevents gaps from appearing between black objects and underlying objects. |
9 . |
In the Options area, enable any of the following: |
Not all options in the Convert to bitmap dialog box are available for all bitmap file formats.
