• | To import a Corel DESIGNER file |
• | Corel DESIGNER (DSF) technical notes |
• | Corel DESIGNER (DES) technical notes |
You can import Corel DESIGNER files. Files from version 10 and later have the filename extension .des. Files from Micrografx versions 6 to 9 have the filename extension .dsf. Version 4 files have the filename extension .ds4. The .drw filename extension is used for a Micrografx 2.x or 3.x file. Micrografx template files (DST) are also supported.
1 . | Click File ![]() |
2 . | Locate the folder in which the file is stored. |
3 . | Choose DES - Corel DESIGNER (*.des) or DSF, DRW, DST, MGX - Corel/Micrografx Designer (*.dsf; *.drw; *.ds4) from the list box next to the File name box. |
4 . | Click the filename. |
5 . | In the Import dialog box, adjust any of the settings. |
6 . | Click Import. |
7 . | Click the drawing page. |
• | Guidelines are preserved. Grid settings are not converted, however. |
• | Snap points are not converted — the program preserves the default gravity settings. |
• | Objects on some pages may be grouped together. You may want to select the group and then ungroup it before editing. |
• | DSF files display OLE data as picture objects. OLE data object types are lost in the conversion. |
• | Curvygons are converted to curves. |
• | Any part of a graphic that is outside the extents that Corel DESIGNER can support cannot be accessed. You should resize the graphic before converting. |
• | Enhanced line styles are preserved. |
• | Gradient transparency may be offset in some cases. |
• | Hatch fills are preserved in the imported file. |
• | Unclosed, filled lines are converted to two objects: one for the line and one for the fill. |
• | Block text in Corel DESIGNER 9 files is converted to paragraph text in Corel DESIGNER 2017. Freeform text is converted to artistic text. |
• | Warped text is converted to curves. |
• | Repelled text (block text that wraps around an object) is converted to multiple text objects. |
• | Each line of a nonrectangular text object (text placed within an object) is converted to a separate text object. |
• | For block text that has many transformations, tab stops may stretch or shrink. |
• | Text flowing between containers is not preserved; each container is converted to a separate object. |
• | Dimensions of text in small caps vary when the text is imported. |
• | Dimension lines and connector lines are converted to curves when you save a file to Corel DESIGNER version 15.0 or earlier. |
