Custom color palettes are collections of colors or color styles that you save. They can include colors or color styles from any color model, including spot colors, or any color palette found in the Palette libraries. You can create a custom palette to store all colors or color styles that you need in a current, or future, project.
It’s easy to share color palettes with others. The custom palettes are accessible from the My palettes folder in the Color Palette Manager.
You can create a custom color palette by choosing individual colors or color styles, or by using the colors in a selected object or an entire document. You can also edit, rename, and delete custom color palettes.
Custom color palettes are saved as XML files and are stored in the My Documents\My Palettes folder.
To create a custom color palette from scratch |
1 . | Click Window ![]() |
2 . | Click the Creates a new empty color palette button |
3 . | Type a filename in the File name box. |
4 . | Click Save. |
5 . | In the Color palette manager, choose the custom palette that you created. |
6 . | Click the Opens the palette editor button |
7 . | In the Palette editor dialog box, click Add color. |
8 . | In the Select color dialog box, choose a color, and click Add to palette. |
In the Selected color area of the Palette editor dialog box, choose Spot from the Treat as list.
In the Selected color area of the Palette editor dialog box, choose Process from the Treat as list.
In the Palette editor dialog box, click a color in the color selection area, and type a name in the Name box.
To add a color to a custom color palette |
1 . | Open a custom color palette. |
2 . | Perform a task from the following table. |
On the custom palette, click the Eyedropper button
In the dialog box, click a color swatch, click the arrow next to Add to palette, choose the name of your custom palette from the list, and then click Add to palette.
To create a color palette from an object |
1 . | Select an object. |
2 . | Click Window ![]() ![]() |
4 . | Click Save. |
To create a color palette from a document |
1 . | Click Window ![]() ![]() |
2 . | Type a filename in the File name box. |
3 . | Click Save. |
To edit a custom color palette |
2 . | Choose a palette from the list box. |
3 . | Perform a task from the following table. |
Click Add color. In the Select color dialog box, click the Models tab, click a color in the color selection area, and click Add to palette.
In the color selection area, click a color, and click Edit color. In the Select color dialog box, click the Models tab, and click a new color in the color selection area.
In the color selection area, click a color, and click Delete color.
Click Sort colors, and choose a color sorting method.
You can delete multiple colors by holding down Shift or Ctrl, clicking the colors that you want to delete, and clicking Delete color.
To rename a custom color palette |
2 . | From the My Palettes folder, right-click a custom palette, and click Rename. |
3 . | Type a new name, and press Enter. |
To delete a custom color palette |
2 . | From the My Palettes folder, right-click a custom palette, and click Delete. |
