You can make objects appear three-dimensional by creating extrusions. You can create extrusions by projecting points from an object and joining them to create an illusion of three dimensions. Corel DESIGNER also lets you apply a vector extrusion to an object in a group.
After you create an extrusion, you can copy or clone its attributes to a selected object. Cloning and copying transfer the extrusion attributes of an extruded object to another. However, the cloned extrusion settings cannot be edited independently from the master.
Corel DESIGNER also lets you remove a vector extrusion.
You can create a bevel effect without extruding an object. For more information, see Creating bevel effects.
You can create a vector extrusion in which the lines of the extrusion converge at a vanishing point. The vanishing point of a vector extrusion can be copied to another object so that both objects appear to recede toward the same point.
You can also give extrusions different vanishing points.
Extrusions with different vanishing points
To create an extrusion |
1 . | Select an object using the Pick tool |
2 . | In the toolbox, click the Extrude tool |
3 . | Choose a preset from the Presets list box on the property bar. |
4 . | Choose an extrusion type from the Extrusion type list box on the property bar. |
If you want to reset the extrusion, press Esc before releasing the mouse button. |
You can also create an extrusion by using the Extrude docker (Effects Extrude).
To copy or clone an extrusion |
1 . | Select the object you want to extrude. |
2 . | Click Effects and click one of the following: |
• | Copy effect ![]() |
• | Clone effect ![]() |
3 . | Click an object whose extrusion properties you want to copy. |
You can also use the Attributes eyedropper tool to copy an extrusion. For more information, see To copy effects from one object to another.
To change the form of a vector extrusion |
Select an extruded object. Click the Extrude rotation button
Using the Extrude tool
In the toolbox, click the Shape tool
To remove a vector extrusion |
1 . | Select an extruded object. |
2 . | Click Effects ![]() |
You can also remove a vector extrusion by clicking the Clear extrusion button on the property bar.
To apply a fill to an extrusion |
1 . | Select an extruded object with the Extrude tool |
2 . | Click the Extrusion color button on the property bar. |
3 . | Click one of the following buttons: |
• | Use object fill |
• | Use solid color |
• | Use color shading |
You can apply an unbroken pattern or texture fill to an object by enabling the Drape fills check box before you click the Use object fill button.
To apply beveled edges to an extrusion |
1 . | In the toolbox, click the Extrude tool |
2 . | Select an extruded object. |
3 . | Click the Extrusion bevels button |
4 . | Enable the Use bevel check box. |
5 . | Type a value in the Bevel depth box. |
6 . | Type a value in the Bevel angle box. |
You can also set the bevel depth and angle by using the Bevel interactive display box below the Use bevel check box.
You can show only the bevel and hide the extrusion by enabling the Show bevel only check box.
To add light to an extrusion |
2 . | Click the Extrusion lighting button |
3 . | Click any of the three Light buttons |
The lights appear as numbered circles in the preview window. |
4 . | Drag the numbered circles in the Light intensity preview window to position the lights. |
If you want to create more realistic shading, enable the Use full color range check box. |
Select a light in the Light intensity preview window, and move the Intensity slider.
Click an active Light button.
To change the vanishing point of an extrusion |
Double-click an extruded object. Choose VP locked to object or VP locked to page from the Vanishing point properties list box on the property bar.
Double-click an extruded object whose vanishing point you want to change. From the Vanishing point properties list box on the property bar, choose Copy VP from. Select the extruded object that has the vanishing point you want to copy.
Double-click an extruded object. Choose Shared vanishing point from the Vanishing point properties list box on the property bar. Select the extruded object that has the vanishing point you want to share.
