You can make styles and style sets available for use in other documents by exporting them to a Corel DESIGNER style sheet (.cdss) file. A style sheet contains all the object styles, style sets, color styles, and default object properties in the active document. You can also use styles and style sets from other documents by importing the style sheet to which they were saved.
1 . |
Click Window Object styles. |
2 . |
In the Object styles docker, click the Import, export, or save defaults button , and click Export style sheet. |
3 . |
In the Export style sheet dialog box, choose the folder where you want to save the style sheet. |
1 . |
2 . |
In the Object styles docker, click the Import, export, or save defaults button , and click Import style sheet. |
3 . |
In the Import style sheet dialog box, choose the folder where the style sheet is stored. |
![*](images/tip.svg)
You can also import styles and style sets from an existing Corel DESIGNER file by selecting the file in the Import style sheet dialog box and clicking Import.
