With Corel DESIGNER, you can create mirror images of objects. Mirroring an object flips it from left to right or top to bottom. By default, the anchor point is in the center of the object.
2 . |
Click Object Transformations Scale and mirror. |
3 . |
In the Transformations docker, enable the Mirror horizontally option or the Mirror vertically option . |
4 . |
In the Transformations docker, click the point on the origin locator that corresponds to the point on the object about which you want to mirror the object. |
You can also mirror a selected object by holding down Ctrl and dragging a selection handle to the opposite side of the object.
