Asian character input is only supported in Corel DESIGNER when using an Asian operating system or when language support is installed on a non-Asian operating system. You can choose a default font and text orientation (either horizontal or vertical) when typing text. When you type artistic or paragraph text, the program uses a default artistic or paragraph text style.
2 . |
Press Esc to ensure that no objects are selected. |
If the Windows Language bar is displayed, you can choose an input method from the Language bar. |
1 . |
Using the Pick tool , select the frame that contains the text whose orientation you want to change. |
2 . |
Click Window Property manager. |
3 . |
In the Property manager docker, click the Frame button to display the frame-related controls. |
![*](images/note.svg)
The default orientation for Asian text is horizontal.
When you change the text orientation from horizontal to vertical, underlines become left lines and overlines become right lines.
The text orientation setting applies to the entire text object. You cannot have text with different orientations in one text object.
![*](images/tip.svg)
If you have Asian text support installed with your operating system, you can also change text orientation by clicking the Vertical text orientation
or Horizontal text orientation
buttons on the Text toolbar.
