• | To insert a table row |
• | To insert a table column |
• | To delete a row or column from a table |
You can insert and delete the rows and columns in a table.
1 . | Select a row in the table. |
2 . | Perform a task from the following table. |
Click Table Insert Row above.
Click Table Insert Row below.
Click Table Insert Insert rows, type a value in the Number of rows box, and enable the Above the selection option.
Click Table Insert Insert rows, type a value in the Number of rows box, and enable the Below the selection option.
When you use either the Row above command or the Row below command from the Table Insert menu, the number of rows that are inserted depends on how many rows you have selected. For example, if you have selected two rows, then two rows are inserted in the table.
1 . | Select a column. |
Click Table Insert Column left.
Click Table Insert Column right.
Click Table Insert Insert columns, type a value in the Number of columns box, and enable the Left of the selection option.
Click Table Insert Insert columns, type a value in the Number of columns box, and enable the Right of the selection option.
When you use the Column left command or the Column right command from the Table Insert menu, the number of columns that are inserted depends on how many columns you have selected. For example, if you have selected two columns, then two columns are inserted in the table.
1 . | Select the row or column that you want to delete. |
Click Table Delete Row.
Click Table Delete Column.
