The default object properties in Corel DESIGNER control the appearance of text and graphic objects in the active document. For example, when you install Corel DESIGNER for the first time, the default properties for graphic objects determine that each new graphic object has a black outline and no fill.
You can modify the default properties of the following types of objects: artistic media, artistic text, callout, dimension, graphic, and paragraph text. When you modify the defaults, Corel DESIGNER automatically saves these changes to the current document. If you want to use the custom settings in subsequent documents that you create, you can set them as the new document defaults.
You can specify which object styles, style sets, color styles, or default object properties in the active drawing are set as the new document defaults.
1 . |
Click Window Object styles. |
2 . |
In the Object styles docker, open the Default object properties folder, and choose one of the following object types: |
Click the Revert to new document default button next to the object type. |
Click the Revert all to new document default button next to the Default object properties folder. |
Right-click the Default object properties folder, and click Revert all to new document default. |
Click the Set as new document default button next to the object type. |
You can also edit the default object properties while editing any object in the document window. Right-click the Default object properties folder in the Objects styles docker, and choose Update default properties when editing objects. Any change you make to an object becomes the default setting for new objects.
1 . |
2 . |
In the Object styles docker, click the Import, export, or save defaults button , and click Set as new document defaults. |
You can also save settings as the default settings for new documents by using the Options dialog box. For more information, see Saving and restoring defaults.
