The Color Palette Manager is a docker that lets you quickly access the available color palettes, including the Document palette and the Color Styles palette, and create custom color palettes. The color palettes in the Color Palette Manager are divided into two main folders: My palettes and Palette libraries.
You can use the My palettes folder to store all the custom color palettes that you create. You can add folders to store and organize your color palettes for different projects. You can also copy a color palette or move it to a different folder. You can open and control the display of all color palettes.
The Palette libraries folder of the Color Palette Manager contains collections of preset color palettes from which you can choose colors. You cannot edit any of the color palettes that are found in the Palette libraries. However, you can create a custom color palette by copying a color palette from the Palette libraries folder. For more information, see Displaying or hiding color palettes in the Palette libraries.
Click Window Color palette manager. |
2 . |
In the My palettes folder, click the Show or hide icon beside the custom palette name. |
![*](images/note.svg)
When you open a legacy custom palette (.cpl) file, it is automatically converted to the XML format (.xml). The XML version is stored in the x:\Documents and Settings\your name\My Documents folder, and also appears in the My palettes folder in the Color Palette Manager.
![*](images/tip.svg)
If the custom color palette (.xml) was saved to the My palettes folder, you can open it by clicking Window
Color palettes and choosing the custom palette from the list.
2 . |
In the My palettes folder, right-click a custom palette, and click one of the following: |
