To speed up the creation of all kinds of technical graphics, from wiring diagrams to architectural designs, Corel DESIGNER has added the Parallel Drawing mode. It allows you to simultaneously draw multiple parallel curves while controlling the distance between them. In addition, you can set the distance between the original line and the parallel line by specifying a value or dragging in the document.
Corel DESIGNER lets you create single or multiple parallel lines and preview them as you draw. You can also add parallel lines to an existing line.
From left to right: Parallel drawing with the 2-point line tool, 3-point curve tool, and Pen tool
You can draw parallel curves simultaneously.
1 . |
Click the Curve tools button, and click a curve tool. |
3 . |
On the Parallel Drawing toolbar, click the Parallel lines button . |
You can also display the Parallel Drawing toolbar by clicking View
Toolbars
Parallel Drawing.
3 . |
On the Parallel Drawing toolbar, specify the settings you want. |
