PostScript (PS) files use PostScript language to describe the layout of text, vector graphics, or bitmaps for printing and display purposes. They can contain multiple pages. PostScript files are imported as a group of objects that you can edit.
PostScript files usually have a .ps filename extension, but you can also import PostScript files with a .prn extension. Files with a .prn filename extension, commonly known as Printer (PRN) files, contain instructions about how a file should be printed. These files let you reprint a document even if the application in which the document was created is not installed on your computer.
During the CorelDRAW Technical Suite 2017 installation, you have the option of installing Ghostscript, which is an application that interprets the PostScript file format. Ghostscript assists the file importing process. If you did not install Ghostscript during the installation, see To install Ghostscript.
You can also import encapsulated PostScript (EPS) files. For more information, see Encapsulated PostScript (EPS).
3 . |
Choose PS, EPS, PRN - PostScript (*.ps; *.eps; *.prn) from the list box next to the File name box. |
5 . |
In the Import text as area, enable one of the following text options: |
Text — preserves text objects in the imported file so that you can edit the text |
Curves — converts text to curves |
![*](images/note.svg)
When the PostScript file contains text converted to curves, the text in the imported file is not editable, even if you choose to import the text as text.
