• | Make sure that your system’s date and time are set correctly. |
• | Make sure that your system has the latest updates installed. |
• | Log in as a user with administrative privileges. |
• | Make sure that you have enough free disk space available on the drive where you want to install the application. |
• | Delete the contents of the system’s TEMP folders to avoid file and memory conflicts. To navigate to the Temp folders, type %temp% in the Search box on the Windows 7 SP1 or Windows 10 Start menu, or the Windows 8.1 desktop. |
• | Install CorelDRAW Technical Suite in its own directory to avoid conflicts with previous versions. |
