The property bar displays the most commonly used functions that are relevant to the active tool or to the task you’re performing. The property bar content changes depending on the tool or task. For example, when you click the Text tool in the toolbox, the property bar displays only text-related commands, such as text, formatting, alignment, and editing tools.
You can customize the contents and position of the property bar to suit your needs, and add controls. For more information, see Customizing the property bar.
The Add preset button lets you save the current settings for reuse.
The Delete preset button lets you delete user-created presets from the Preset list box.
The Fill button lets you open a dialog box where you set up a fill to apply to an object.
The Outline pen button opens a dialog box where you set line properties.
The Geometric properties button opens the Property Manager docker and lets you set coordinates for the selected object.
The Keep settings button lets you use the current settings as the defaults for new objects.
