You can compress bitmap images, text, and line art to reduce the size of a PDF file. Options for bitmap image compression include JPEG, LZW, and ZIP. Bitmap images that use JPEG compression have a quality scale ranging from 2 (high quality, less compression) to 255 (lower quality, more compression). The higher the image quality, the larger the file size.
You can also reduce the size of a PDF file by downsampling color, grayscale, or monochrome bitmap images.
1 . |
Click File Publish to PDF. |
The PDF settings dialog box appears. |
![*](images/note.svg)
The JP2 (JPEG 2000) option is available only for Adobe Acrobat 6.0, Adobe Acrobat 8.0, and Adobe Acrobat 9.0
![*](images/tip.svg)
If you choose JPEG compression, you can specify the compression quality by moving the JPEG quality slider.
1 . |
6 . |
Enable the Compress text and line art check box. |
1 . |
Downsampling color, grayscale, or monochrome bitmap images is effective only when the resolution of the bitmap image is higher than the resolution specified in the Bitmap downsampling area.
