• | To save and share a fill or transparency |
After you create or modify a fill or transparency pattern, you can save it and add tags (keywords) in the language of your choice. Fills and patterns are saved in a special file format with a .fill extension, which preserves information about the transformations applied to the fill or pattern.
1 . | In the Fill or Transparency section of the Property manager docker, click the Save as new button |
2 . | In the Save pattern dialog box, choose a language from the list box, type a name for the fill or pattern, and type any tags (keywords) that you want to associate with it. |
If you want to share the fill or pattern, enable the Share this content check box, and choose a category from the list. |
You must sign in to your corel.com account to share content on the Content Exchange.
Fills and patterns in your personal library are saved in the My Documents\Corel\Corel Content\Fills folder.
You can also share a fill or pattern from your personal library to the Content Exchange. For more information, see To manage fills and transparencies.
