• | To save a drawing |
• | To use advanced options when saving |
• | To save a drawing that is compatible with an older version of Corel DESIGNER |
By default, drawings are saved to the Corel DESIGNER file format (DES). You can save a drawing to other vector file formats as well. If you want to use a drawing in another application, you must save it to a file format that is supported by that application. For information about saving files to other formats, see Exporting files.
When saving a drawing, you can embed the used fonts to facilitate file sharing. By default, Corel DESIGNER embeds all used fonts, with the exception of Asian fonts and fonts that do not have embedding permissions. For more information, see Embedding fonts.
When you save a drawing, Corel DESIGNER lets you add reference information so that you can easily find and organize drawings later on. You can attach tags (also known as properties) such as title, subject, and rating.
When saving a file, you can use advanced options to control how bitmaps, textures, and vector effects, such as blends and extrusions, are saved with the drawing.
You can also save a drawing as a template, which lets you create other drawings with the same properties. For information about saving a drawing as a template, see Working with templates.
To save a drawing |
1 . | Click File ![]() |
2 . | Type a filename in the File name box. |
3 . | Locate the folder where you want to save the file. |
If you want to save the drawing to a vector file format other than DES - Corel DESIGNER, choose a file format from the Save as type list box. |
Enable the Selected only check box.
Enable the Embed fonts check box.
If you are using an expired trial version of Corel DESIGNER, you will not be able to save drawings.
Saving a drawing to a previous version of Corel DESIGNER may result in loss of certain effects that were not available in the previous version of the application.
You can also save a drawing by clicking File Save.
You can also save a drawing by clicking the Save button on the Standard toolbar.
2 . | Click Advanced. |
3 . | Enable any of the following check boxes: |
• | Save presentation exchange (CMX) — saves a drawing as a Corel Presentations Exchange (CMX) file so that you can open and edit it in other Corel applications, such as WordPerfect |
• | Use bitmap compression — reduces the file size by compressing bitmap effects, such as bitmap extrusions, transparencies, and drop shadows |
• | Use graphic object compression — reduces the file size by compressing vector objects, such as polygons, rectangles, ellipses, and perfect shapes |
Using compression increases the time required for opening and saving a drawing. |
4 . | If a drawing contains texture fills, enable one of the following options: |
• | Save textures with the file — saves custom texture fills with the file |
• | Rebuild textures when opening the file — re-creates texture fills when you open the saved drawing |
5 . | If a drawing contains blends and extrusions, enable one of the following options: |
• | Save blends and extrudes with the file — saves all blends and extrusions included in a drawing |
• | Rebuild blends and extrudes when opening the file — re-creates blends and extrusions when you open the saved drawing |
4 . | Choose a version from the Version list box. |
5 . | Click Save. |
If the drawing includes new features; enable one of the following options in the Save to a previous version dialog box: |
• | Keep appearance — preserves the appearance of text, fills, outlines and transparencies when the file is opened in a previous version of Corel DESIGNER. However, this option may limit editing. |
• | Keep editable — preserves the file editable. However, this option may change the appearance of text, outlines, fills, and transparencies when the file is opened in a previous version of Corel DESIGNER. |
Click Tool
Click Tool
