You can scan images in Corel DESIGNER. Corel DESIGNER supports scanners that use Microsoft Windows Image Acquisition (WIA), which provides a standard interface for scanning images.
If your scanner does not support WIA, but has a compatible TWAIN driver, you may be able to use this driver for scanning images in Corel DESIGNER. TWAIN is supported by both the 32-bit and 64-bit versions of Corel DESIGNER. However, note that there are very few 64-bit TWAIN drivers available.
The software interfaces and options vary. For information about using the software associated with your scanner, see the manufacturer’s documentation.
1 . |
Click File Acquire image, and click one of the following commands: |
4 . |
Click File Acquire image Acquire. |
To scan additional images during the same session, click File
Acquire image
Acquire.
