• | To apply an envelope |
• | To copy an envelope |
• | To edit the nodes and segments of an envelope |
• | To change the mapping mode |
Corel DESIGNER lets you shape objects, including lines, artistic text, and paragraph text frames by applying envelopes to them. Envelopes are made of multiple nodes that you can move to shape the envelope and, as a result, change the shape of the object. You can apply a basic envelope that conforms to the shape of an object, or you can also apply a preset envelope. After you apply an envelope, you can edit it or add a new envelope to continue changing the object’s shape. Corel DESIGNER also lets you copy and remove envelopes.
You can edit an envelope by adding and positioning its nodes. Adding nodes gives you more control over the shape of the object contained in the envelope. Corel DESIGNER also lets you delete nodes, move multiple nodes simultaneously, change nodes from one type to another, and change a segment of an envelope to a line or curve. For more information about the different types of nodes, see Using curve objects.
1 . | Select an object. |
2 . | In the toolbox, click the Envelope tool |
3 . | On the property bar, click one of the following buttons: |
• | Straight line mode |
• | Single-arc mode |
• | Double-arc mode |
• | Unconstrained mode |
4 . | Click the object. |
5 . | Drag the nodes to shape the envelope. |
If you want to reset the envelope, press Esc before releasing the mouse. |
Click the Add preset button on the property bar, and click an envelope shape.
Click the Add new envelope button
Click Effects
You can also apply an envelope by using the Envelope docker (Effects Envelope).
You can prevent the object’s straight lines from being converted to curves by enabling the Keep lines button on the property bar.
1 . | Select an object to which you want to copy an envelope. |
2 . | Click Effects ![]() ![]() |
3 . | Select the object from which you want to copy the envelope. |
You can also copy an envelope by selecting an object, clicking the Copy envelope properties button on the property bar, and selecting an object with the envelope you want to copy.
You can also use the Eyedropper tool to copy an envelope. For more information, see To copy effects from one object to another.
1 . | In the toolbox, click the Envelope tool |
2 . | Select an object with an envelope. |
3 . | Double-click the envelope to add a node or double-click a node to delete it. |
Click the Unconstrained mode button
On the property bar, choose Rectangular from the Selection mode list box, and drag around the nodes that you want to select.
On the property bar, choose Freehand from the Selection mode list box, and drag around the nodes you want to select.
Press Ctrl, select two opposing nodes, and drag them to a new position.
Click the Single-arc mode
Click the Unconstrained mode button on the property bar so that it appears pressed, and click either the Cusp node
Click the Unconstrained mode button on the property bar so that it appears pressed, click a line segment, and click the Convert to line
1 . | In the toolbox, click the Envelope |
2 . | Click an object with an envelope. |
3 . | On the property bar, choose one of the following from the Mapping mode list box: |
• | Horizontal — stretches the object to fit the basic dimensions of the envelope and then compresses the object horizontally to fit the shape of the envelope |
• | Original — maps the corner handles of the object’s selection box to the envelope’s corner nodes. The other nodes are mapped linearly along the edge of the object’s selection box. |
• | Putty — maps the corner handles of the object’s selection box to the envelope corner nodes |
• | Vertical — stretches the object to fit the basic dimensions of the envelope and then compresses the object vertically to fit the shape of the envelope |
4 . | Drag the nodes or the control handles. |
The mapping mode of paragraph text frames cannot be changed after an envelope is applied.
