• | To skew an object |
When you skew an object, you slant it horizontally, vertically, or both. You can specify the degree by which you want to slant the object. You can also change the skew and sizing anchor point of an object from its default center position.
To skew an object |
1 . | Select an object. |
2 . | Click the Shape tools button in the toolbox, and click the Free transform tool |
3 . | Click the Free skew button |
If you want to change the object’s reference point to use when skewing the object, locate the Object origin icon ![]() |
4 . | Type values in the Skew angle boxes on the property bar. |
Click the Relative to object button
Skew an object using the Transformations docker
Click Object
In the Transformations docker, enable the Use anchor point check box, and click the point on the origin locator
In the Transformations docker, type a number in the Copies box.
If you move the skew anchor point, you can reset it to the center again by clicking Object Clear transformations.
You can also skew an object interactively by dragging one of its skew handles.
You can also skew an object by typing values in the Skew angle boxes on the Transform toolbar. To display the Transform toolbar, click View Toolbars
Transform.
