• | To set the page size and orientation |
• | To add or delete custom preset page sizes |
• | To choose a layout style |
• | To use a label style |
• | To save the current page layout as the default |
You can choose from more than 800 preset label formats from different label manufacturers. You can preview the dimensions of labels and see how they fit on a printed page. If Corel DESIGNER does not provide a label style that meets your requirements, you can modify an existing style or create and save your own original style.
1 . | Click Layout ![]() |
The Options dialog box appears with the Page size page displayed. |
2 . | Perform a task from the following table. |
Choose a page size from the Size list box.
Click the Get page size from printer button.
Type values in the Width and Height boxes.
Click the Landscape or the Portrait button.
Make sure that the page you want to change is displayed in the drawing window, choose a page size and orientation, and enable the Apply size to current page only check box.
Enable the Show page border check box.
Click Add page frame.
Choose a resolution from the Rendering resolution list box.
Enable the Show bleed area check box, and type a value in the Bleed box.
You can also specify the page size and orientation by clicking View Page sorter view and adjusting the controls on the property bar.
You can also open the Options dialog box with the Page size page displayed by double-clicking the shadow of the drawing page.
Specify a custom page size in the Width and Height boxes, click the Save button, and type a name for the custom page in the Save custom page type as box.
The custom preset page size appears in the Size list box.
Choose a page size from the Size list box, and click the Delete button.
With the Pick tool active and no objects selected, you can also add or delete custom preset page sizes by clicking Edit this list at the bottom of the Page size list box on the property bar.
2 . | In the Options dialog box, choose a layout style from the Layout list box. |
Each layout style is accompanied by a short description and illustration. |
2 . | In the Document list of categories, click Label, and enable the Labels option. |
3 . | Choose a manufacturer name from the list. |
4 . | Choose the label style you want from the list. |
If you want to customize the label style, click Customize label, and adjust the label size, margins, gutters, and the number of labels appearing on each sheet. |
If you want to save the custom label style you created, click the Add button ![]() |
You cannot use label styles if a drawing contains multiple pages.
For best results, choose Letter paper size and Portrait orientation before applying a label style.
1 . | Click Tools ![]() |
2 . | In the list of categories, click Document. |
3 . | Enable the Save options as defaults for new documents check box. |
4 . | Enable the Page options check box. |
