• | To start a drawing |
• | To create a custom preset |
• | To open a drawing |
Corel DESIGNER lets you start a new drawing from a blank page, a template, or an existing drawing. A blank page gives you the freedom to specify every aspect of a drawing. A template provides you with a starting point and leaves the amount of customization up to you. The templates included with the application are available under the following categories:
• | ANSI (American National Standards Institute) |
• | Architectural |
• | DIN (Deutsches Institut für Normung) |
• | Engineering |
• | ISO (International Organization for Standardization) |
For information about starting a drawing from a template, see To start a document from a template. For more information about creating and using templates, see Working with templates.
Notes for starting new drawings
When starting a new drawing, Corel DESIGNER lets you specify page, document, and color management settings. You can choose from a list of preset settings, which are based on how you intend to use the drawing. For example, you can choose the Web option if you are creating a drawing for the Internet, or the Default CMYK option if you are creating a document destined for commercial printing. However, if the preset settings are not suitable for the drawing that you want to create, you can also customize the settings and save them for future use.
Notes for opening existing drawings
Basing a new drawing on an existing drawing lets you reuse objects and page settings. Corel DESIGNER lets you open existing drawings saved to the Corel DESIGNER (DSF or DES) format as well as drawings and projects saved to various other file formats, such as CorelDRAW (CDR), Adobe Illustrator (AI), Adobe Portable Document Format (PDF), Encapsulated PostScript (EPS), and Computer Graphics Metafile (CGM). However, you may not be able to open certain files, depending on their file type and contents. In such cases, you can try importing the files as objects in an open drawing. For information about the file formats that you can import into Corel DESIGNER, see Supported file formats.
If the drawing you are opening is from an earlier version of Corel DESIGNER and contains text in a language different from the language of your operating system, you can choose code page settings to ensure that text is properly converted according to the Unicode Standard. Code page settings help you correctly display text such as keywords, file names, and text entries outside the drawing window — for example, in the Object manager and Object data manager dockers. To display text correctly in the drawing window, you must use encoding settings. For more information, see Displaying text correctly in any language.
If the drawing you are opening contains an embedded International Color Consortium (ICC) profile, the embedded color profile remains the document’s color profile. For more information, see Understanding color management.
You can search for drawings by different criteria, such as filename, title, subject, author, keyword, comment, text within the file, and other properties attached to the file. For more information about searching for files, see the Windows Help. For more information about browsing and searching for content, see Browsing and searching for content.
You can also display previous versions of a drawing.
1 . | Do one of the following: |
• | On the Welcome screen, click Get started ![]() |
• | In the application window, click File ![]() |
2 . | Type a filename in the Name text box. |
3 . | From the Preset destination list box, choose an output destination for the drawing: |
• | Corel DESIGNER default — applies the Corel DESIGNER default settings for creating graphics that are destined for printing |
• | Default CMYK — applies settings for creating graphics that are destined for commercial printing |
• | Default RGB — applies settings for creating graphics that are destined for printing to a high-fidelity printer |
• | Web — applies settings for creating graphics that are destined for the Internet |
• | Custom — lets you customize destination settings for a document |
Choose a unit of measurement from the Drawing units list box.
Choose a page size for the drawing from the Size list box or type values in the Width and Height boxes.
Type a value in the Number of pages box.
Choose a color mode from the Primary color mode list box.
Choose a rendering resolution from the Rendering resolution list box.
Choose a preview mode from the Preview mode list box.
In the Color settings area, choose a default RGB profile from the RGB profile list box.
Choose a default CMYK profile from the CMYK profile list box.
Choose a default Grayscale profile from the Grayscale profile list box.
Choose an option from the Rendering intent list box.
When you choose a color mode from the Primary color mode list box, it becomes the default color mode for the document. The default color mode affects how colors work together in effects such as blends and transparencies. It does not restrict the type of colors that you can apply to a drawing. For example, if you set the color mode to RGB, you can still apply colors from a CMYK color palette to the document.
The settings that are displayed in the Color settings area of the Create a new document dialog box are based on the settings that are specified in the Default color management settings dialog box.
If you do not want to show the Create a new document dialog box and prefer to use the last used settings to create new documents, enable the Do not show this dialog again check box.
You can restore the Create a new document dialog box when starting drawings by clicking Tools Options, clicking General in the Workspace list of categories, and enabling the Show new document dialog box check box.
1 . | In the application window, click File ![]() |
2 . | In the Create a new document dialog box, choose the settings that you want to save as a preset destination. |
3 . | Click the Add preset button |
4 . | In the Add preset dialog box, type a name for the new destination preset. |
You can delete a destination preset by choosing the preset name from the Preset destination list box and clicking the Remove preset button.
To open a drawing |
1 . | Click File ![]() |
2 . | Locate the folder where the drawing is stored. |
3 . | Click a filename. |
4 . | Click Open. |
Enable the Extract embedded ICC profile check box.
Enable the Maintain layers and pages check box.
Click the arrow button next to the Views button, and click Extra large icons, Large icons, Medium icons, or Small icons.
Choose a code page from the Select code page list box. This option is not available for all file formats.
Right-click a file, and click Restore previous versions.
To open a file you have recently worked on, click File Open Recent, and click the filename.
If you have multiple files open, you can navigate between them by clicking Window Document, and then clicking the name of the file that you want to display in the drawing window.
