• | To sync trays with OneDrive |
You can sync your trays with OneDrive and have access to your content from other computers or mobile devices. You must have a OneDrive account to use this feature. After you sign in, you can see all your OneDrive folders in the Libraries pane in the Get More docker and view their content in the viewing pane.
After you sign in, your OneDrive folders appear in the Libraries pane.
Trays are stored in My Documents\Corel\Corel Content\Trays. Each tray is stored as a separate folder. If the trays have never been synced with OneDrive, each tray folder contains shortcuts to the files that have been added to the tray, while the actual files remain in their original location. However, when you sync the trays with OneDrive, all files added to the trays are copied from their original location to the respective tray folder.
When you sync trays with OneDrive, the synced files appear in the following OneDrive folder: OneDrive\Apps\Corel\Trays.
1 . | Click File ![]() |
2 . | Click OneDrive in the Libraries pane. |
3 . | Sign in when prompted. |
4 . | When asked whether you want to enable Tray Sync, click Yes. |
5 . | Make sure that the Enable Tray Sync with OneDrive on this computer check box is enabled, and choose an option from the Sync frequency list box. |
Your OneDrive folders and content appear in the viewing pane. |
Select the file in the viewing pane, and click the Import button
Select the file in the tray, and click the Remove from tray button
In the viewing pane, right-click a OneDrive file or folder, and choose Open source location from the context menu.
Right-click the file, and then click Properties.
In the Libraries pane, click the Configure content libraries button
The tray tab icons indicate the sync status of the tray: offline , error
, syncing
, or synced
You can enable and disable Tray Sync directly from the Tray docker by clicking the All trays arrow in the lower-left corner and then clicking Synchronize with OneDrive.
