You can transform the color and tone of an image to produce a special effect. For example, you can create an image that looks like a photographic negative or flatten the appearance of an image. To transform the color and tone of images, you can use the following effects:
Deinterlace — lets you remove lines from scanned or interlaced images |
Invert — lets you reverse the colors of an image. Inverting an image creates the appearance of a photographic negative. |
Posterize — lets you reduce the number of tonal values in an image. Posterize removes gradations and creates larger areas of flat color. |
2 . |
Click Effects Transform, and click any of the following: |
