• | To enable or disable alignment guides |
• | To modify alignment guide settings |
• | To add margin alignment guides |
You can align objects interactively on the drawing page by using alignment guides. Alignment guides are temporary guidelines that appear when you create, resize, or move objects in relation to nearby objects. While dynamic guides provide precise measurements for creating technical illustrations, alignment guides are useful in page layout to align text or graphic elements quickly and accurately.
Alignment guides appear as an object is moved.
You can offset (left) and inset (right) margin alignment guides.
1 . | Click Tools ![]() |
2 . | In the Alignment and dynamic guides docker, click the Alignment guides button |
3 . | Enable or disable the check box in the upper-right corner of the Alignment guides section. |
You can also enable or disable alignment guides by clicking the Alignment guides button on the Layout toolbar. To open the Layout toolbar, click Layout Layout toolbar or View
Toolbars
Layout.
You can also enable alignment guides by pressing Shift + Alt + A.
3 . | Perform any of the following tasks. |
Open the Line color picker, and choose a color.
Open the Line style picker, and choose a line style.
Click the Object edges button
Click the Object centers button
Click the Individual objects in a group button
Ensure that the Intelligent spacing button
Ensure that the Intelligent spacing button is enabled, and drag the object between two other objects until indicator arrows appear.
Ensure that the Intelligent dimensioning button
Ensure that the Intelligent dimensioning button is enabled, and rotate the object until rotation indicators appear.
You can access some alignment guide controls on the Layout toolbar by clicking the Layout toolbar button .
Enable the Margins check box. If the Margins check box is not displayed, click the arrow button
Open the Margin line color picker, and choose a color.
Open the Margin line style picker, and choose a line style.
Type a value in the Horizontal margin box, click the Horizontal margin button, and choose one of the following options:
Type a value in the Vertical margin box, click the Vertical margin button, and choose one of the following options:
Click the Lock ratio button
Disable the Object edges button
Click the Horizontal margin button, and choose No horizontal margin
Click the Vertical margin button, and choose No vertical margin
