A checking style is a preset writing style rule applied to a drawing. Using a checking style lets you check a drawing that has a specific type of writing. For example, you can choose an advertising checking style to check advertising copy or marketing materials.
You can create, delete, edit, and restore a checking style.
You can specify a maximum number of items when Grammatik checks the grammar of a drawing. For example, you can specify the maximum number of consecutive nouns that Grammatik allows.
Choosing a formality level lets Grammatik check a drawing for strict or relaxed use of language and diction. Each checking style has a default level of formality assigned to it. Each formality level focuses on a different style of writing. You can choose from three formality levels: informal, standard, and formal.
1 . |
Click Text Writing tools Grammatik. |
2 . |
Click Options Checking styles. |
3 . |
In the Checking styles dialog box, choose one of the following: |
A checking style remains in effect until you disable the checking style or choose another one.
1 . |
2 . |
3 . |
In the Checking styles dialog box, choose Very strict from the list. |
5 . |
In the Edit checking styles dialog box, disable any rule classes in the Rule classes list that you do not want to include. |
8 . |
In the Save as checking style dialog box, type a name in the Custom style name box. |
1 . |
2 . |
3 . |
In the Checking styles dialog box, choose a checking style from the list. |
You can delete custom checking styles, but you cannot delete preset checking styles.
1 . |
2 . |
3 . |
In the Checking styles dialog box, choose a checking style. |
When you save an edited checking style, an asterisk (*) is added to the style name.
1 . |
2 . |
3 . |
In the Checking styles dialog box, choose an edited checking style from the list. |
Custom checking styles saved with new names cannot be returned to default settings.
1 . |
2 . |
3 . |
5 . |
In the Maximum allowed area, type values in any of the following boxes: |
Set the Spell numbers below or equal to value to zero if you do not want numerals to be flagged as errors.
1 . |
2 . |
3 . |
5 . |
In the Formality levels area, enable one of the following: |
