You can specify a projected drawing mode by choosing drawing profiles and drawing planes from the Drawing plane toolbar. However, you can have only one drawing profile and one drawing plane active at a time.
You can draw an object in a projected drawing mode, or you can project an object onto a drawing plane. You can also unproject an object from a drawing plane; this reconstructs the object as it would appear in an orthographic view.
Click View Toolbars Drawing plane. |
2 . |
Click Object Transformations Project. |
3 . |
In the Transformations docker, choose Project from the list box. |
4 . |
In the Plane area, click one of the following buttons: |
Top — projects the object onto the top plane |
Front — projects the object onto the front plane |
Right — projects the object onto the right plane |
Type values in the X and Y boxes to specify coordinates along the horizontal and vertical axes. |
Click the Specify point button next to the X and Y boxes, and click a point on the drawing. |
Enable the Relative origin check box, and click the point on the origin locator that corresponds to the point on the object from which you want to project the object. |
Applying a contour to a projected object may not produce the desired results. It is recommended that you apply a contour to the object in its unprojected state and then project the object. Contour groups can be unlinked by clicking Arrange
Break contour group apart.
2 . |
3 . |
In the Transformations docker, choose Unproject from the list box. |
4 . |
Top — unprojects the object from the top plane |
Front — unprojects the object from the front plane |
Right — unprojects the object from the right plane |
Enable the Relative origin check box, and click the point on the origin locator that corresponds to the point on the object from which you want to unproject the object. |
