Rule classes contain groups of grammar and style rules. Grammatik uses rule classes to detect common writing errors.
You can enable or disable rules at any time during a Grammatik session. When you disable a rule, Grammatik ignores all the errors associated with that rule during the current proofreading session. You can also choose which rule classes to apply during a Grammatik session or save a new set of rules as a checking style.
1 . |
Click Text Writing tools Grammatik. |
2 . |
Click Options Turn on rules. |
3 . |
In the Turn on rules dialog box, choose the rules you want to enable from the Rules list. |
![*](images/note.svg)
The Turn on rules command is available only when you have disabled a rule during proofreading. Otherwise, it is grayed.
1 . |
1 . |
2 . |
Click Options Checking styles. |
3 . |
In the Checking styles dialog box, choose a checking style from the list. |
5 . |
In the Edit checking styles dialog box, enable any check boxes beside the rule classes in the Rule classes list that you want to add. |
1 . |
2 . |
Click Options Save rules. |
3 . |
In the Save rules dialog box, click Save as. |
4 . |
In the Save as checking style dialog box, type a name in the Custom style name box. |
The Save rules command is available only when a rule has been turned off.
