Several view options are available in the Color styles docker to help your work with color styles more easily.
Page Sorter view displays thumbnails of all pages in a document. When you edit a color style in Page Sorter view, you can see how all objects that use the color style are changed. You can change the size of the page thumbnails to suit your needs.
Hint view shows what objects are associated with color styles. When you point to a color style in the Color styles docker, an indicator marks the object that uses the color style in the document window.
Hint view helps you identify objects that use specific color styles.
In addition, you can show larger color swatches, and you can view empty arms in color harmonies in the Harmony editor.
Two of the arms in this color harmony, based on the Tetrad harmony rule, do not contain any colors, but are displayed to help with editing tasks.
1 . |
Click Window Color styles. |
2 . |
In the Color styles docker, click the View options button , and click Page sorter view. |
![*](images/tip.svg)
To return to the default page view, click the Page sorter view button
on the property bar.
1 . |
2 . |
In the Color styles docker, click the View options button , and click Hint view. |
1 . |
2 . |
In the Color styles docker, click the View options button , and click Use large swatches. |
1 . |
2 . |
In the Color styles docker, click the View options button , and click Show empty arms. |
