The application provides color management presets, which are default color settings that are applied to new and untagged documents. You can choose a color management preset that is suitable for the geographic region where a document is created or for the location of its final output.
You can also create your own presets, which allows you to retain your selections in the Default color management settings dialog box and reuse them in other documents. If you no longer need a preset, you can delete it.
1 . |
Click Tools Color management Default settings. |
Europe Prepress — suitable for designs that will be printed by print service providers in Europe |
Europe Web — suitable for web designs that are created in Europe |
Japan Prepress — suitable for designs that will be printed by print service providers in Japan |
Japan Web — suitable for web designs that are created in Japan |
Minimal Color Management — preserves the original RGB, CMYK, and Grayscale color values when opening, importing, or pasting documents |
North America Prepress — suitable for designs that will be printed by print service providers in North America |
Simulate Color Management Off — produces the color-conversion results of the Color Management Off preset that is available in earlier versions of Corel DESIGNER |
Simulate Corel DESIGNER Technical Suite X4 — displays colors as they appear in Corel DESIGNER Technical Suite X4 |
1 . |
3 . |
Click the Save button next to the Presets list box. |
4 . |
In the Save color management style dialog box, type a name in the Save style as box. |
1 . |
