• | To assign a language to text |
A drawing can contain text that alternates between different languages. For example, if English is the default language of your computer’s operating system, and you also have a French language module installed, you can use the writing tools to check the spelling or grammar of both French and English text. When you run the spelling checker or Grammatik, Corel DESIGNER checks words, phrases, and sentences according to their assigned language. This prevents foreign words from being marked as misspellings. You can use the writing tools the same way you would if the text were all in one language.
For more information about installing a Writing Tools language module, see Changing the language.
You can also specify which quotation marks to use for different languages. For more information, see To customize quotation marks for different languages.
1 . | Select the text. |
2 . | Click Text ![]() ![]() |
3 . | In the Text language dialog box, choose a language from the list. |
You can assign a language to selected words, sentences, or paragraphs.
To use the writing tools for the language you select in the Text language dialog box, the module for that language must be installed.
