Enhanced export support for CGM and SVG files makes it easier to publish you illustrations to technical communication standards.
When exporting CGM files, you can preserve the level of detail and use full bitmap compression. In addition, it is easier to export to interactive WebCGM 2.x files, preserving the attributes apsid and apsname in the XML Companion File (XCF).
The attribute apsname must be added to the objectdata.xml file. If you add
apsname in the Object data manager docker in Corel DESIGNER, only the
field name is captured in the XML Companion File (XCF), not the apsname
attribute.
SVG export can be automated, while still preserving all detail settings in the exported files.
