Objects created in Corel DESIGNER follow a path that gives them their defining shape. When this path is broken or cut, subpaths remain.
Paths outline an object’s shape and are often visible as one or more line or curve
segments. You can disconnect line segments from one another to create subpaths.
Even though they are not connected, subpaths are still part of the defining path of
the original object; however, you can extract a subpath to create two separate
objects: the extracted subpath and the object it was extracted from.
Subpaths are the basic curves and shapes from which a single curve object is
constructed. For example, a single curve object with subpaths is often created when
text is converted to curves. The letter “O,” for instance, is composed of two ellipses:
the outside ellipse that defines the letter’s shape and the inside ellipse that defines
the “hole.” The ellipses are subpaths that compose the single curve object, “O”.
One of the basic reasons for creating an object with subpaths is that you can
produce objects with holes in them.
1) The letter “O” is converted to curves. 2) The resulting subpaths are the outside ellipse that defines the shape of the letter and the inside ellipse (tinted gray) that defines the hole. 3) In comparison, the black ellipse consists of a single path and cannot contain a “hole.”
