Corel DESIGNER provides preset drawing profiles for working in projected drawing modes. After choosing a drawing profile, you then draw or project objects onto its three drawing planes (top, front, and right) to create the illusion of a three-dimensional image. When you close your drawing, the last drawing profile you used is saved along with it; this drawing profile is automatically activated the next time you open the file.
Corel DESIGNER provides 11 preset drawing profiles:
one isometric (default)
four dimetric
four trimetric
one cavalier oblique
one cabinet oblique
You can choose a different drawing profile at any time; however, if you change drawing profiles after you have begun a project, the geometry of your existing objects will not change.
If the preset drawing profiles do not meet your needs, you can create new ones or edit existing ones. For more information, see Customizing drawing profiles.
Each default drawing profile is associated with a set of three numbers, which correspond to the x, y, and z axes, respectively. The x-axis is measured in degrees, clockwise from a line perpendicular to the y-axis. The y-axis is measured in degrees, counterclockwise from the true horizontal, which is 0° east. The z-axis is measured in degrees, counterclockwise from a line perpendicular to the y-axis. The isometric drawing profile, for example, has measurements of (30,90,30) while the cavalier oblique drawing profile has measurements of (0,90,45).
This image depicts a cube displayed by using eight different drawing profiles.
Top row, left to right: Dimetric (37,90,37); Dimetric (16,90,37); Dimetric (7,90,42); Dimetric (15,90,15).
Bottom row, left to right: Trimetric (12,90,23); Trimetric (5,90,30); Trimetric (45,90,7); Trimetric (54,90,17)
You can choose to work from one of four drawing planes:
orthographic — draws on a flat plane, such as the top, front, or right drawing
plane
top — draws onto a projected plane bounded by the x and z axes defined in the
drawing profile
front — draws onto a projected plane bounded by the x and y axes defined in the
drawing profile
right — draws onto a projected plane bounded by the y and z axes defined in the
drawing profile
The default drawing plane is orthographic. Although you can change drawing planes at any time, only one drawing plane can be active at a time.
In this example, a drawing profile is depicted. The x-axis is 37° clockwise from a line perpendicular to the y-axis. The y-axis is 105° counterclockwise from the true horizontal. The z-axis is 37° counterclockwise from a line perpendicular to the y-axis. Therefore, the drawing profile has a value of (37,105, 37).
