Corel DESIGNER Help sitemap | Contents
Getting started
Welcome
Installing CorelDRAW Technical Suite applications
Changing languages
Changing startup settings
Updating Corel products
Corel Support Services
About Corel
What’s new in Corel DESIGNER X6?
Access and repurpose technical design assets
Illustrate with style and consistency
Publish to technical communication standards
Increase performance, speed, and efficiency
Learning resources
Getting help
Using the Help and tooltips
Welcome screen
Macro programming guide
Network deployment guide
Web-based resources
Customized training and integration resources
Corel DESIGNER workspace tour
Corel DESIGNER terms and concepts
Corel DESIGNER application window
Corel DESIGNER workspace tools
Corel DESIGNER basics
Understanding vector graphics and bitmaps
Starting and opening drawings
Acquiring images from scanners and digital cameras
Undoing, redoing, and repeating actions
Zooming, panning, and scrolling
Previewing drawings
Choosing viewing modes
Working with views
Saving drawings
Backing up and recovering files
Adding and accessing drawing information
Closing drawings and quitting Corel DESIGNER
Finding and managing content
Exploring Corel CONNECT
Accessing content
Browsing and searching for content
Viewing content
Using content
Installing pattern fills and fonts
Managing content
Working with precision
Using gravity snapping
Using dynamic guides
Using alignment guides
Using constrain keys
Using object coordinates
Collaborating
Using ConceptShare
Lines, shapes, and outlines
Working with lines, outlines, and brushstrokes
Setting the default property values
Drawing lines
Closing multiple line segments
Drawing callouts
Drawing connector lines
Drawing dimension lines
Formatting lines and outlines
Adding arrowheads to lines and curves
Drawing calligraphic, pressure-sensitive, and preset lines
Applying linear-pattern brushstrokes
Spraying linear patterns along a line
Drawing shapes
Drawing rectangles and squares
Drawing ellipses, circles, arcs, and wedges
Drawing polygons and stars
Drawing grids
Drawing predefined shapes
Drawing projected shapes
Drawing by using shape recognition
Shaping objects
Working with curve objects
Shaping curve objects by using Reflect Nodes mode
Cropping, splitting, and erasing objects
Trimming objects
Filleting, scalloping, and chamfering corners of curve objects
Welding and intersecting objects
Creating new objects from boundaries
Creating PowerClip objects
Smudging and smearing objects
Adding twirl effects
Roughening objects
Shaping objects by attracting or pushing away nodes
Applying distortion effects
Shaping objects by using envelopes
Reference: Shaping objects
Projecting objects
Understanding projected drawing modes
Using projected drawing modes
Customizing drawing profiles
Objects, symbols, and layers
Working with objects
Selecting objects
Changing object properties
Copying, duplicating, and deleting objects
Copying object properties, transformations, and effects
Cloning objects
Moving objects
Sizing and scaling objects
Rotating objects
Mirroring objects
Skewing objects
Aligning and distributing objects
Changing the order of objects
Grouping objects
Combining objects
Locking objects
Finding and replacing objects
Accessing and displaying geometric information about objects
Inserting bar codes
Working with symbols
Using symbols in drawings
Managing collections and libraries
Creating, editing, and deleting symbols
Sharing symbols between drawings
Reference: Working with symbols
Creating objects for the Web
Exporting bitmaps for the Web
Saving and applying Web presets
Exporting objects with transparent colors and backgrounds
Creating rollovers
Adding bookmarks and hyperlinks to documents
Adding hotspots and alternate text to objects
Working with layers
Creating layers
Changing layer properties
Moving and copying layers and objects
Object linking and embedding
Inserting linked or embedded objects
Editing linked or embedded objects
Working with object data
Setting up the project database
Managing object data
Applying CGM data to objects
Color and fills
Working with color
Understanding color models
Understanding color depth
Choosing colors
Using the Document palette
Creating and editing custom color palettes
Organizing and displaying color palettes
Displaying or hiding color palettes in the Palette libraries
Setting the properties of color palettes
Filling objects
Applying uniform fills
Applying fountain fills
Applying hatch fills
Applying pattern fills
Applying texture fills
Applying PostScript texture fills
Applying mesh fills
Applying fills to areas
Working with fills
Using color management
Understanding color management
Getting started with color management in Corel DESIGNER
Installing, loading, and embedding color profiles
Assigning color profiles
Converting colors to other color profiles
Choosing color-conversion settings
Soft proofing
Working with color management presets
Working with color management policies
Managing colors when opening documents
Managing colors when importing and pasting files
Managing colors for print
Using a safe CMYK workflow
Managing colors for online viewing
Special effects
Adding 3D effects to objects
Contouring objects
Applying perspective to objects
Creating extrusions
Creating bevel effects
Creating drop shadows
Blending objects
Changing the transparency of objects
Applying transparencies
Applying merge modes
Using lenses with objects
Applying lenses
Editing lenses
Text
Adding and manipulating text
Importing and pasting text
Adding artistic text
Adding paragraph text
Adding columns to text frames
Combining and linking paragraph text frames
Aligning text by using the baseline grid
Selecting text
Finding, editing, and converting text
Shifting, rotating, mirroring, and flipping text
Moving text
Wrapping text
Fitting text to a path
Embedding graphics and adding special characters
Working with legacy text
Formatting text
Choosing typefaces and fonts
Formatting characters
Changing text color
Kerning a range of characters
Changing text case
Working with OpenType features
Adjusting character and word spacing
Adjusting line and paragraph spacing
Adding bullets to text
Inserting drop caps
Changing character position and angle
Aligning text
Adding tabs and indents
Working with text styles
Hyphenating text
Inserting formatting codes
Displaying nonprinting characters
Working with text in different languages
Formatting Asian text
Using line-breaking rules for Asian text
OpenType support for Asian text
Formatting multilingual text
Displaying text correctly in any language
Managing fonts
Substituting fonts
Previewing and displaying fonts
Using writing tools
Using QuickCorrect
Using the spelling checker and Grammatik
Using the thesaurus
Working with languages
Customizing the writing tools
Using checking styles
Using rule classes
Analyzing a drawing
Using word lists
Checking statistics
Reference: Using writing tools
Templates and styles
Working with templates
Searching for templates
Using templates
Creating templates
Editing templates
Working with styles and style sets
Creating styles and style sets
Applying styles and style sets
Editing styles and style sets
Managing default object properties
Exporting and importing style sheets
Assigning keyboard shortcuts to styles or style sets
Finding objects that use a specific style or style set
Breaking the link between objects and styles or style sets
Working with color styles
Creating and applying color styles
Editing color styles
Exporting and importing color styles
Breaking the link between a color style and an object
Pages and layout
Working with pages and layout tools
Specifying the page layout
Choosing a page background
Adding, duplicating, renaming, and deleting pages
Inserting page numbers
Using the rulers
Calibrating the rulers
Setting up the document grid
Setting up the baseline grid
Setting up guidelines
Modifying guidelines
Setting the drawing scale
Working with tables
Adding tables to drawings
Selecting, moving, and navigating table components
Inserting and deleting table rows and columns
Resizing table cells, rows, and columns
Formatting tables and cells
Working with text in tables
Converting tables to text
Merging and splitting tables and cells
Manipulating tables as objects
Adding images, graphics, and backgrounds to tables
Importing tables in a drawing
Bitmaps
Working with bitmaps
Converting vector graphics to bitmaps
Importing bitmaps
Cropping bitmaps
Changing the dimensions and resolution of bitmaps
Straightening bitmaps
Using Digimarc watermarks to identify bitmaps
Removing dust and scratch marks from bitmaps
Applying special effects in bitmaps
Working with colors in bitmaps
Using the Image Adjustment Lab
Adjusting color and tone
Using the Tone Curve filter
Transforming color and tone
Editing bitmaps with Corel PHOTO-PAINT
Working with bitmap color modes
Changing the color mode of bitmaps
Changing bitmaps to black-and-white images
Changing bitmaps to duotones
Changing bitmaps to the paletted color mode
Tracing bitmaps and editing traced results
Tracing bitmaps
PowerTRACE controls
Previewing traced results
Fine-tuning traced results
Adjusting colors in traced results
Setting default tracing options
Tips for tracing bitmaps and editing traced results
Working with RAW camera files
Using RAW camera files
Bringing RAW camera files into Corel DESIGNER
Adjusting the color and tone of RAW camera files
Sharpening and reducing noise in RAW camera files
Previewing RAW camera files and obtaining image information
Printing
Printing basics
Printing your work
Laying out print jobs
Previewing print jobs
Applying print styles
Fine-tuning print jobs
Printing colors accurately
Printing to a PostScript printer
Using print merge
Viewing preflight summaries
Preparing files for print service providers
Preparing a print job for a print service provider
Working with imposition layouts
Printing printers’ marks
Maintaining OPI links
Printing color separations
Working with color trapping and overprinting
Specifying In-RIP trapping settings
Printing to film
Working with a print service provider
File formats
Importing and exporting files
Importing files
Exporting files
Working with 3D models
Installing XVL Studio 3D Corel Edition
Importing 3D models
Inserting and adjusting 3D models
Exporting to PDF
Exporting documents as PDF files
Including hyperlinks, bookmarks, and thumbnails in PDF files
Reducing the size of PDF files
Working with text and fonts in PDF files
Specifying an encoding format for PDF files
Specifying a viewing option for EPS files
Specifying color management options for exporting PDF files
Setting security options for PDF files
Optimizing PDF files
Viewing preflight summaries for PDF files
Preparing PDF files for a print provider
Working with office productivity applications
Importing files from office productivity applications
Exporting files to office productivity applications
Adding objects to documents
Exporting to HTML
Setting preferences for exporting images to HTML
Creating Web-compatible text
Previewing and verifying files before exporting to HTML
Exporting to HTML
Supported file formats
3D file formats
Adobe Illustrator (AI)
Adobe Type 1 Font (PFB)
Windows Bitmap (BMP)
OS/2 Bitmap (BMP)
Computer Graphics Metafile (CGM)
CorelDRAW (CDR)
Corel Presentation Exchange (CMX)
Corel PHOTO-PAINT (CPT)
Corel Symbol Library (CSL)
Cursor Resource (CUR)
Microsoft Word (DOC, DOCX, or RTF)
Microsoft Publisher (PUB)
Corel DESIGNER (DES, DSF, DS4, or DRW)
AutoCAD Drawing Database (DWG) and AutoCAD Drawing Interchange Format (DXF)
Encapsulated PostScript (EPS)
PostScript (PS or PRN)
GIF
HTML
JPEG (JPG)
JPEG 2000 (JP2)
Kodak Photo CD Image (PCD)
PICT (PCT)
PaintBrush (PCX)
Adobe Portable Document Format (PDF)
HPGL Plotter File (PLT)
Portable Network Graphics (PNG)
Adobe Photoshop (PSD)
Corel Painter (RIF)
Scalable Vector Graphics (SVG)
Adobe Flash (SWF)
TARGA (TGA)
TIFF
TrueType Font (TTF)
Visio (VSD)
WordPerfect Document (WPD)
WordPerfect Graphic (WPG)
RAW camera file formats
Wavelet Compressed Bitmap (WI)
Windows Metafile Format (WMF)
Additional file formats
Recommended formats for importing graphics
Recommended formats for exporting graphics
General notes on importing text files
Customizing and automating
Setting basic preferences
Disabling warning messages
Viewing system information
Corel Application Recovery Manager (Windows XP)
Customizing Corel DESIGNER
Saving defaults
Using multiple workspaces
Customizing keyboard shortcuts
Customizing menus
Customizing toolbars
Customizing the property bar
Customizing the status bar
Customizing feedback sounds
Customizing filters
Customizing file associations
Using macros to automate tasks
Working with macros
Reference
Glossary
