• | To add artistic text |
Artistic text is useful for adding single words or short lines of text, such as headlines, to a document. You can then apply a wide range of effects to the artistic text, such as drop shadows or a contour.
Artistic text appears in a bounding box in the document window
You can add artistic text along an open or closed path or fit existing artistic to a path. For more information, see Fitting text to a path.
In addition, you can assign hyperlinks to text. For more information, see To assign a hyperlink to text.
• | Using the Text tool ![]() |
You can convert artistic text to paragraph text by selecting the artistic text using the Pick tool and then clicking Text
Convert to paragraph text.
