| • | To modify a tab stop |
| • | To add a tab stop |
| • | To indent paragraph text |
| 1 . | Click Window |
| 2 . | In the Property manager docker, click the Paragraph button |
| 3 . | In the Paragraph area of the Property manager docker, click the arrow button |
| 4 . | Click the Tab settings button. |
| 5 . | Perform a task from the following table. |
Click the cell in the Alignment column, and choose an alignment option from the list box.
Click the cell in the Leaders column, and choose On from the list box.
Click the cell, and click Remove.
Click Leader options, open the Character picker, and click a character.
Click Leader options, and type a value in the Spacing box.
You can also add, move, or delete tab stops on the horizontal ruler at the top of the drawing window. Click to add a tab stop, drag a tab marker to move it, and drag a tab marker off the ruler to delete it. For information about rulers, see Using the rulers.
| To add a tab stop |
| 1 . | Using the Text tool |
| 2 . | Click Window |
| 3 . | In the Property manager docker, click the Paragraph button |
| 4 . | In the Paragraph area of the Property manager docker, click the arrow button |
| 5 . | Click the Tab settings button |
| 6 . | Click Add. |
| 7 . | Click the new cell in the Tabs column, and type a value. |
| 4 . | In the Paragraph area of the Property manager docker, type values in the following boxes: |
| • | First line indent — indents the first line of text relative to the left side of the frame |
| • | Left line indent — creates a hanging indent relative to the left side of the text frame; all lines, except the first line, are indented |
| • | Right line indent — indents the text relative to the right side of the frame |
You can remove indents by typing 0 in the First line indent, Left line indent, and Right line indent boxes.
You can indent an entire paragraph by typing the same value in both the First line indent and the Left line indent boxes.
