| • | To apply a perspective |
| • | To copy an object’s perspective effect |
| • | To adjust the perspective |
| • | To remove a perspective effect from an object |
You can create a perspective effect by shortening one or two sides of an object. This effect gives an object the appearance of receding in one or two directions, thereby creating a one-point perspective or a two-point perspective.
Perspective effects can be added to objects or grouped objects. You can also add a perspective effect to linked groups, such as contours, blends, and extrusions. You can’t add perspective effects to paragraph text, bitmaps, or symbols.
Click Effects
Click Effects
Pressing Ctrl constrains the node’s movement to the horizontal or vertical axis to create a one-point perspective effect.
You can move opposing nodes the same distance in opposite directions by pressing Ctrl + Shift as you drag.
| 1 . | Select an object to which you want to apply a perspective effect. |
| 2 . | Click Effects |
| 3 . | Select an object whose perspective effect you want to copy. |
You can also use the Attributes eyedropper tool
to copy a perspective effect. For more information, see To copy effects from one object to another.
| 1 . | In the toolbox, click the Shape tool |
| 2 . | Select an object that has a perspective effect. |
| 3 . | Drag a node to a new position. |
You can also adjust the perspective by dragging one or both of the vanishing points.
You can move opposing nodes the same distance in opposite directions by pressing Ctrl + Shift while dragging the node.
| 1 . | Select an object that has a perspective effect. |
