You can assign a keyboard shortcut to a style or style set. When you press the keyboard shortcut, Corel DESIGNER applies the style or style set to the selected object. A keyboard shortcut can use up to four different keystrokes.
If a keyboard shortcut is already assigned to another command, you can override the existing setting.
For more information about working with keyboard shortcuts, see Customizing keyboard shortcuts.
1 . |
Click Window Object styles. |
2 . |
In the Object styles docker, right-click a style or style set, and click Assign keyboard shortcut. |
The Options dialog box opens with the Shortcut keys tab of the Commands page displayed and Apply styles in the top list box selected. |
4 . |
Click in the New shortcut key box, and press a key combination. |
If the same keyboard shortcut is already assigned to another command, the second assignment overwrites the first. By enabling the Navigate to conflict on assign check box, you can automatically navigate to the command whose shortcut you reassigned and assign a new shortcut.
