AutoCAD Drawing Database (DWG) files are vector files used as a native format for AutoCAD drawings.
To import an AutoCAD Drawing Database file (DWG) or AutoCAD Drawing Interchange Format (DXF) |
1 . | Click File Import. |
2 . | Locate the folder in which the file is stored. |
3 . | Choose DWG - AutoCAD (*.dwg) or DXF - AutoCAD (*.dxf) from the list box next to the File name box. |
4 . | Click the filename. |
5 . | Click Import. |
6 . | From the 3D projection list box in the Import AutoCAD file dialog box, choose a plane projection of a three-dimensional object as seen from a given focal point. |
If you want to reduce the number of nodes on the imported object, enable the Auto-reduce nodes check box. |
7 . | In the Scaling area, enable one of the following options: |
• | Automatic — scales the drawing using the scale of the AutoCAD source file |
• | English (1 unit = 1 inch) — lets you scale the drawing in inches |
• | Metric (1 unit = 1 mm) — lets you scale the drawing in millimeters |
8 . | Click OK. |
If the file is password protected, type the password in the Password box. |
If views are specified in your file, they appear automatically in the 3D projection list box.
If your computer is missing a font that is included in a file you are importing, a PANOSE font matching dialog box appears and lets you substitute the font with a similar font.
To export an AutoCAD Drawing Database file (DWG) or an AutoCAD Drawing Interchange file (DXF) |
1 . | Click File Export. |
2 . | Locate the folder in which you want to save the file. |
3 . | From the Save as type list box, choose one of the following options: |
• | DWG - AutoCAD |
• | DXF - AutoCAD |
4 . | Type a filename in the File name list box. |
5 . | Click Export. |
6 . | In the Export to AutoCAD dialog box, choose an AutoCAD version from the Export version list box. |
7 . | Choose a unit of measure from the Export units list box. |
8 . | In the Export text as area, enable one of the following options: |
• | Curves — lets you export text as curves |
• | Text — lets you export text as editable characters |
9 . | In the Export bitmap as area, enable one of the options to export the bitmaps in a drawing to a supported bitmap format. |
10 . | In the Fill unmapped fills area, enable one of the following options: |
• | Color — fills all unmapped fills with color. To change the color, click the Color picker and choose a color on the palette. |
• | Unfilled — leaves unmapped fills unfilled |
AutoCAD Data Interchange Format (DXF) technical notes |
• | The program supports AutoCAD files from version R2.5 to 2015. |
• | Layers are retained on import and export. |
• | Corel graphics programs try to center the imported image. The image is scaled down if the coordinates are larger than the maximum page size available in Corel DESIGNER — 150 × 150 feet. |
• | Model space pages are imported as master pages. |
• | Solid and trace entities are filled. |
• | Dimension lines are imported as dimension objects. |
• | A point is imported as an ellipse of minimum size. |
• | Files exported as "Entities only" may not appear as expected in the Corel program because of a lack of header information. |
• | Imported AutoCAD files that contain formatted paragraph text preserve text formatting such as spacing, alignment, and indents. |
• | Justification of text entries may not be preserved, especially if fonts are replaced in the imported files. For best results, avoid justification of text. |
• | If the DXF file contains a font that is not on the user’s computer, the PANOSE font matching dialog box lets the user replace the font with an available one. |
• | Lines with a number of points that exceed the maximum supported in Corel DESIGNER will be broken into multiple lines, and their fills will be dropped. |
• | 3D solids are not directly supported in Corel DESIGNER. Users can import 3D solids with the 3D Import program. |
• | Password protection is not available in the exported files. |
• | Only the outlines of objects are exported. |
• | Filled objects with no outlines have an outline appended to them on export. |
• | All text is exported by using a generic font. Text formatting is not preserved. |
AutoCAD Drawing Database (DWG) technical notes |
• | Corel DESIGNER can import AutoCAD files from version R2.5 to 2015 and export AutoCAD files from version R2.5 to 2015. |
• | If the DWG file contains a font that is not on your computer, the PANOSE font matching dialog box lets you replace the font with an available one. |
