You can choose the color and type of background for a drawing. For example, you can use a solid color if you want a uniform background. If you want a more intricate or dynamic background, you can use a bitmap.
When you choose a bitmap as the background, it is embedded in the drawing by default. This option is recommended. However, you can also link the bitmap to the drawing so that if you later edit the source image, the change is automatically reflected in the drawing. If you send a drawing with a linked image to someone else, you must also send the linked image.
You can make a background bitmap printable and exportable, or you can save computer resources by exporting and printing a drawing without the background bitmap.
If you no longer need a background, you can remove it.
1 . |
Click Layout Page background. |
When you export files to a bitmap format, the background color is used for anti-aliasing edges. If the bitmaps are of irregular shape and will be placed against a background different from white, it is recommended that you select a matching page background color. For example, if you are planning to place the exported bitmap against a blue background, you may want to choose a similar blue color for the page background.
1 . |
6 . |
In the Options dialog box, enable one of the following options: |
Linked — links the bitmap to the drawing so that changes made to the source file are reflected in the bitmap background |
Embedded — embeds the bitmap in the drawing so that changes made to the source file are not reflected in the bitmap background |
Custom size — lets you specify the dimensions of the bitmap by typing values in the H and V boxes. |
If the bitmap is smaller than the drawing page, it is tiled across the drawing page. If it is larger than the drawing page, it is cropped to fit the drawing page.
A background bitmap is not an object and cannot be edited.
1 . |
