If you no longer want table text to appear in a table, you can convert the table text to paragraph text. For more information about converting text to a table, see To create a table from text.
1 . |
Click the Table tool , and then click the table. |
2 . |
Click Table Convert table to text. |
3 . |
In the Separate cell text with area, choose one of the following options: |
Commas — replaces each column with a comma and replaces each row with a paragraph marker |
Tabs — replaces each column with a tab and replaces each row with a paragraph marker |
User defined — replaces each column with a specified character and replaces each row with a paragraph marker |
If you enable the User defined option, you must type a character in the User defined box. |
![*](images/note.gif)
If you do not type a character in the User defined box, each of the table rows is converted into a paragraph, and the table columns are ignored.
