You can copy a transparency from one object to another. If you want to apply the same transparency to other objects or simultaneously modify the transparency attributes of multiple objects in a drawing, you can save the transparency settings as a style. For more information about styles, see Working with styles and style sets.
When you position a transparency over an object, you can freeze it, making the view of the object move with the transparency.
You can also remove the transparency from an object.
| 3 . |
Click the Copy transparency button on the property bar. |
| 3 . |
Click the Freeze transparency button on the property bar. |
The view of the object beneath the transparency moves with it; however, the actual object remains unchanged.
| 2 . |
In the Transparency area of the Property manager docker, click the No transparency button . |
