You can create color styles from the colors of an existing object or from scratch. When you create a color style, the new color style is saved to the active document and to the Color styles palette.
After you create a color style, you can apply it to objects in the document. Corel DESIGNER lets you access available color styles through various controls: the Color styles docker, the Object styles docker, the Property manager docker, the Color styles palette, and the Document palette. (A color style is automatically added to the Document palette when you apply it to an object.)
Color styles can be combined into groups called harmonies. A harmony allows you to link color styles into hue-based relationships and modify them together as a set. By editing color styles in a harmony, you can quickly create a variety of alternate color schemes by shifting the colors together, or you can alter the color composition of your artwork in one step.
Corel DESIGNER allows you to create a special type of color harmony called a gradient. A gradient consists of a master color style and a number of shades of that color style. For most of the available color models and palettes, the derivative color styles share the same hue as the master color style but have different saturation and brightness levels. With the PANTONE MATCHING SYSTEM and Custom spot color palettes, the master color style and the derivative color styles are linked to one another but have different tint levels.
You can create a harmony from the colors of an existing object or from scratch.
Corel DESIGNER also lets you select all color styles that are not used in the document or merge unwanted color styles into others. It also lets you convert color styles to different color modes or to spot colors to prepare your document for production printing.
2 . |
Click Window Color styles. |
3 . |
In the Color styles docker, click the New color style button , and choose New from selected. |
4 . |
In the Create color styles dialog box, enable one of the following options in the Create color styles from area: |
Object fill — creates a color style from the color of the object fill |
Object outline — creates a color style from the color of the object outline |
To convert the color styles to a different color mode, enable the Convert all color styles to check box, and choose a color mode from the list box.
You can also create color styles or color harmonies from a selected object by using any of the following methods:
1 . |
You can also create a color style by clicking the New color style button , choosing New color style, and choosing a color in the Color editor. The Color editor provides a variety of options to choose the right color: Eyedropper tool, color viewers, sliders, and palettes. For more information about choosing colors, see Working with color.
If you want to create color styles from all the colors in your document, do one of the following:
In the Color styles docker, click the New color style button , and choose New from document. |
On the Color styles palette, click the arrow button and choose Add from Document. |
1 . |
2 . |
In the Color styles docker, click the New color harmony button , and choose New color harmony. |
You can also duplicate a harmony by selecting its folder in the Color styles docker, clicking the New color harmony button , and choosing Duplicate harmony.
You can resize the Color harmonies area so that you can view available color harmonies without scrolling by pointing to the grab area, and when the cursor changes to a two-directional arrow, dragging the edge of the pane.
1 . |
2 . |
In the Color styles docker, select a color style as the master color for the gradient. |
3 . |
Click the New color harmony button , and choose New gradient. |
4 . |
In the New gradient dialog box, specify the number of shades in the Number of colors box. |
Lighter shades — creates shades that are lighter than the master color |
Darker shades — creates shades that are darker than the master color |
Both — creates an equal number of light and dark shades |
1 . |
3 . |
In the Color styles docker, do one of the following: |
Click the Merge button .
Select two color styles in the Color styles docker, and click the Swap color styles button . The fill color style becomes the object outline, and the outline color style becomes the object fill.
Click the Select unused button .
You can also apply a color style to a selected object by using any of the following methods:
On the Color styles palette or the Document palette, click a color style to apply a fill or right-click a color style to apply an outline. To open the Color styles palette, click Window Color palettes Color styles palette. |
In the Outline or Fill section of the Property manager docker, click the source indicator next to the color picker, and choose from the list of previously created color styles. |
You can also use the Object styles docker to apply a color style, if the object style that is assigned to an object contains a color attribute, such as a fill or outline. In the style properties area of the Object styles docker, click the source indicator next to a color picker, and choose from the list of previously saved color styles. |
