| • | To create a layer |
| • | To make a layer active |
| • | To display pages, layers, and objects in the Object Manager docker |
| • | To delete a layer |
All Corel DESIGNER drawings consist of stacked objects. The vertical order of these objects — the stacking order — contributes to the appearance of the drawing. An effective way to organize these objects is by using invisible planes called layers.
Drawings can be assembled by placing objects on various levels or layers.
Local layers and master layers
The Object manager docker displays the default layer structure. The names of the active page and layer appear at the top.
| • | Guides — stores page-specific (local) guidelines. All objects placed on the Guides layer appear as outlines only, and the outlines act as guidelines. |
| • | Layer 1 — represents the default local layer. When you draw objects on the page, the objects are added to this layer unless you choose a different layer. |
| • | Guides (all pages) — contains the guidelines that are used for all pages of the document. All objects placed on the Guides layer appear as outlines only, and the outlines act as guidelines. |
| • | Desktop — contains objects that are outside the borders of the drawing page. This layer lets you store objects that you may want to include in the drawing at a later time. |
| • | Document grid — contains the document grid that is used for all pages of the document. The document grid is always the bottom layer. |
The default layers on the master page cannot be deleted or copied.
To add content to a layer, you must first select the layer so that it becomes the active layer.
Viewing layers, pages, and objects
You can choose different views that let you display pages, layers, or all the objects in your document. The view you choose depends on the complexity of your document and the task you are performing. For example, in a long multipage document, you can choose a pages-only view so that you can navigate the document more easily and view only one page at a time. The Current page, layers only view lets you view and reorder all the layers that affect the current page, including the master layers.
| To create a layer |
| 1 . | If the Object manager docker is not open, click Window |
| 2 . | Perform a task from the following table. |
In the upper-right corner of the Object manager docker, click the flyout button
To use a layer in the drawing, you must first make the layer active by clicking the layer name in the Object manager docker. The layer name appears in a red bold font to indicate that it is the active layer. When you start a drawing, the default layer (Layer 1) is the active layer.
Master layers for odd and even pages cannot be created in Facing Pages view. If you have created odd and even master pages before switching to Facing Pages view, the odd and even master layers will be converted to all-page master layers. For more information about facing pages, see To view facing pages.
You can also add a layer by clicking the New layer button
You can also create new master layers by clicking the respective button in the Object manager docker: New master layer (all pages)
, New master layer (odd pages)
, or New master layer (even pages)
You can make any layer a master layer by right-clicking the layer name, and clicking Master (all pages), Master (odd pages), or Master (even pages).
| 2 . | In the Object manager docker, click the layer name. |
| The layer name appears in a red bold font to indicate that it is the active layer. |
By default, the active layer is Layer 1.
Click the flyout button
Click the name of a page, click the Layer manager view button
Click the Layer manager view button
Display selected objects in the Object manager docker
| To delete a layer |
| 2 . | Click the name of a layer. |
| 3 . | Click the flyout button |
When you delete a layer, you also delete all the objects on it. To preserve an object, move it to a different layer before you delete the current layer.
You can delete any unlocked layer except the following default layers: Document grid, Desktop, Guides, and Guides (all pages). For more information about locking and unlocking layers, see To set the editing properties of a layer.
You can also delete a layer by right-clicking the layer name in the Object manager docker and choosing Delete.
