You can create workspaces to make more accessible the tools that you use most often. For example, you can open dockers or add tools to toolbars. You can also delete the custom workspaces that you create. If you modify the default workspace, you can reset the default settings.
In addition, you can export and import custom workspaces to and from other computers that use the same application. For example, you can customize a workspace and share it with a group of users.
| 5 . |
From the Base new workspace on list box, choose an existing workspace on which to base the new workspace. |
You cannot delete the Default and Adobe Photoshop workspaces.
| 4 . |
In the Import workspace dialog box, click Browse. |
The workspace items available for export are dockers, toolbars (including the property bar and toolbox), menus, and shortcut keys.
A workspace is exported as a .cdws file.
