• | To add a filter |
• | To remove a filter |
• | To change the order of the list of filters |
Filters are used to convert files from one format to another. They are organized into four types: raster, vector, animation, and text. You can customize filter settings by adding or removing filters so that only the filters you need are loaded. You can also change the order of the list of filters and reset filters to the default setting.
To add a filter |
1 . | Click Tools Options. |
2 . | In the list of categories, double-click Global, and double-click Filters. |
3 . | Double-click a type of filter in the Available file types list. |
4 . | Click a filter. |
5 . | Click Add. |
2 . | In the list of categories, double-click Global, and click Filters. |
3 . | Click a filter in the List of active filters. |
4 . | Click Remove. |
4 . | Click one of the following: |
• | Move up — moves the filter up the list |
• | Move down — moves the filter down the list |
You can reset the List of active filters to the default setting by clicking Reset.
